Hi Guys,
Let me just clear a few things up on here.
We did the remap and after it was done my mobile agent checked logs on the car to make sure everything is running perfect (which it was) - this was done via VAG-COM after the remap so if there was any issues trying to communicate with the ECU it would have been picked up here.
Personally I believe the dealer is just trying to fob you off, as I have worked at a Seat dealer I know how they work
As I said to you, we will be more than happy to check over the car to point you in the right direction and give you advice. This would mean coming to us or local agent, which I have tried to book an appointment.
It sounds to us like you are loosing fuel rail pressure over time, check to hear on the first stage of ignition the in-tank pump is working. Sounds like you are having to build fuel pressure before the engine will start.
We have never had this
problem before with any other Leon’s we have done; I hope you can get it sorted asap!
Kind Regards
Custom-Code
