Too hot?
caveo
While booting my newly IHI'd cupra i noticed a drop in boost to almost sod all and i saw my water temp was at 120!!!!!! after slowing down it took 5 mins to get back to 90. I have a forge fmic and checked all the hoses so called jbs who said it may be the water pump and all in with the timing belt changed it will cost 320 quid! Is this a common fault and is there an uprated option??
RikH
Texas Cowboy
Oct 17, 2005
2,474
Yorkshire
if its never had belt changed it will still have plastic impellared water pump
a common fail item
you need a metal impellar'd pump, and whilst your doing that you should change all belts and ancilliaries. circa 200quid for parts
caveo
ill let you know how i get on , its booked in at jbs on tuesday
russman68
146
Surrey
Just so you know i got a brass impeller pump from eurocar parts for 23.92 inc VAT
Part number: 201440655 (Golf IV)
Ninja
Cupra now gone :(
Oct 1, 2005
1,182
Reading
www.peugeot-gti.net
surely if the water pump had gone it wouldnt have cooled down when you slowed down and took it easy ?
Mine didnt start cooling till i was on the hard shoulder of the m4 lol.. Then again my (plastic) water pump impellor had shattered!!
lofer
Atlantis to Interzone
Apr 11, 2007
770
Holbeach
When mine went water temperatures would stay at 90 if I kept the revs under 3k. I think mine had split and was spinning on the shaft. :blink:
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
better you just don't drive it........... head gaskets & a reskimmed head costs a fair whack
caveo
Good news guys !! i is back on boost as jbs sorted my water pump out on monday morning , the old plastic one was cracked and just spinning on the shaft so temps were just silly high the drive to chesterfield was not much fun and very slow but 320 quid , a new metel pump and a cam belt change later the fun is back:D
chriswilks
Astra CDTi track car
Jun 3, 2007
330
warrington cheshire
320 quid isnt too, bad i paid 370 for the same job at awesome,a job well done so i dont mind!!mine did this when i tried to overtake a 318i on the motorway!!oh the embarrasement when he left me!!
