sory to ask something so obvious, but you did check this by opening the door to see if the light came on didnt you?
(this is to check the door switch is working and therefore activate the alarm).
i've got this as well, some kind of door sensor error apparently, as the light comes on when i open the passengers side door but not the drivers side, something in the drivers door itself!
Yeh pop the drivers end of the dash off and check your fuses. I only had lights on one side after I changed my sidelights. I'd blown a fuse - both sides are on different fuses. Quite clever really.
