Wierd Sound coming from the front of my car?
Chrisdaman
1 gearbox dead, any more?
Mar 21, 2007
2,106
Kingston
www.flickr.com
right this is quite hard to explain
when i pull off there is a grinding / squeak sound, it's intermittent, but regularly, and gets faster the faster i go. When i put my foot down on the clutch the noise disappears, but it also disappears when i turn left. When i turn right it gets much worse
is this the wheel bearing?
any help or enlightenment would be great
Chris
Chrisdaman
Mar 21, 2007
2,106
Kingston
www.flickr.com
that's what i was thinking, but when i slow down to a standstill still in gear i hear a slow grinding noise, not permanent, it's on and off, like when something is out of line?
really hard to explain
Dolly_Gti
G60 spooling up.
Aug 15, 2006
1,412
china town
i was tempted to say, that'll be the charger lol...
but yeh sounds like bearing to me, depressing the clutch takes the load off the driveshafts/bearings and so the noise goes...
Turning a corner loads up the outside wheel, so if it gets worse turning right, then that would indicate the left front bearing..
( i think i got it the right way round, if someone can back me up :) )
Edit, read the last post, does it happen at standstill? or cruising to a standstill... if it happens not moving maybe its gearbox related?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
wheel bearing or possibly the dreaded SMDS :p
self machining diff sydrome
i have a similar one but i reckon its the gearbox second shaft bearing
Chrisdaman
Mar 21, 2007
2,106
Kingston
www.flickr.com
i reckon it's the wheel bearing, which is a *******, gotta do my brakes anyway lol
anybody know where to get a bearing press from? or is it better to take the whole lot apart and take it to somewhere with a press (i have a run around car if this is the case)
