If you have shoes on the back, then im sure you can adjust it at the wheel. You'll need to take the wheel off and then through the holes (where the bolts that hold the wheel on go) if you look there a spring. All you have to do is pull it down. You'll have to use a really thin screw driver. If you have a haynes manual check it out on there.
