if you ask frenchy on here with the part numbers he can find out for you he is a audi parts dept but can get all vag parts there might get it a bit cheaper? say that i gave u his name tho :)
Mmmm, I quite like the idea of doing this. More for the change to the lower bumper than the small grilles either side of the S badge.
So, am I right in thinking, as has been said above that:
the S badge & grille stays as it is, but the 2 grilles to either side of this are replaced with honeycomb bits? And then, the foglights get new surrounds and the slatted middle section of the lower bumper is replaced with honeycomb? I am assuming the old fogs fit straight in?
It looks from the first two photo's posted that there are some 'struts' coming down across the lower bumper between the fogs and the centre section. Are they part of the centre honeycomb assembly?
No worries.
I was looking at this also, I took the cheaper option. :)
If going for the Cupra bumper you need the FMIC too - which is costly all in... though there is also the option of the facelift FR bumper.
What does the face lift look like? I'm thinking about buying some cupra alloys from someone on here, they are expensive though - £500ish
This is the facelift bumper.
just to let u all know i got the fulls set of grills (top and bottom) for the prefacelift bumper for £38 including vat from the stealers!!
