Pics
Okay pull the side panel off
Take the rubber grommet out (keep it for later - I forgot to put mine back in
) There is a second grommet behind that - poke that through with a coat hanger. Make a small hole in the first rubber grommet and put the cable through to prevent water. Then push the Red Power cable through the two holes.
Now put your hand in the side panel hole and feel behind the foam (small arms
help!) Try and get a hold of the red power cable (quite footery!)
Then pull it through (leaving enough to connect to the battery and fuse with a little bit of slack too).
Now start to lift the panels and wire it straight into the boot.
Hopefully you'll be able to understand this. Any questions just ask.
And remember to run the red power cable and remote wire from your CDplayer
up the passenger side and the RCA's up the drivers side.
