New Goodies Being Fitted. :D
Jun 19, 2007
419
haha me and jas have been trying to work it out. he recons near 20k i dont recon anywhere near that i said around than 10
Nov 2, 2004
9,335
South Wales
Well is runs. :D
Diff is the best thing i've ever bought for the car, i cant even begin to describe how good it is powering out of roundabouts etc...!
Clutch is evil and something isnt right somewhere as its making a strange grinding like noise when in gear without touching any of the pedals, so overun basically.
May 2, 2006
2,758
my clutch has a little rattle when on idle
was told this was totally normal with these clutches
is yours a rattle or a grind?
loving the sound of your diff :D
Nov 2, 2004
9,335
South Wales
Nah the clutch seems fine, so do the gears, no noise on driving just on overrun. I had the flywheel lightened with the clutch so that should help with the chatter.
Theres zero rattle from the clutch.
The sound, sounds like its coming from the diff/driveshaft area, its a griding noise with a slight knock/rattle.
Its drives amazingly with no problems at all, no crunching, everything engages well etc..., but this is buggin the **** out of me, the guy who built my box is gonna take a listen to it on the weekend before it comes out again.
If you can afford it, the diff is awesome even on the power i'm running!
Had a new ISP last night so i havent had chance to set up my network connection so i can upload the photos, but i should be able to do it tonight.
9,335
South Wales
****, i just realised i've exceeded my bandwidth on photobucket! lol. Over 27gb usage this month so far! Might have to upgrade it.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Any way of checking that? Its a constant noise in overrun, be it on the flat, straight or in bends.
I could well be wrong, don't want to put you to any unnecessary work....
Is your front suspension adjustable... if so, raise it up and see if the noise goes?
:doh: edit, or more simply get the front jacked up wheels free of the ground and turn the wheels by hand. There should be sufficient angle on the driveshaft to eliminate then?
9,335
South Wales
Might be an idea. I'll have a good nose round and get my 'box man to have a listen as well this weekend.
Just worried something grinding badly and spray shavings everywhere. But it doesnt seem to be gettin better or worse.
Maybe its just gear lash coz of the lightened fly, diff and different final drive and i just need some thicker box oil, i dont know.
