fuel economy
sean135
hi. i bought a 1998 1.4 seat ibiza sxe. could sombody please tell me how many mpg i should be getting because i cant work it out from my hand book.
also i am getting a pool of water on the drivers side floor dose anybody have any idea of were it is comming from. thanks.sean
alb
63
Sheffield
I have a 1.4 and i am getting about 260 miles per full tank (35 litres, or about £40). This is really low though, and i think that my lambda sensor needs replacing.
The pool of water could be caused by something like the door/window seal leaking maybe. Do you have a sunroof? Also, on my old (1994) corsa there was a whole under the wheel arch, and water splashed in and made a puddle when it rained.
dan
Cupra Kid
Has a TDI!!
Oct 13, 2005
3,380
Chesterfield, Derbyshire
Water is probably a torn door liner letting water in, you changed the speakers or anything lately in the door? Soak that area of the car with a hose and look for water getting in........ theres not a more technical way i'm afraid.
An ibiza is a 9gallon tank full so if your getting 300miles your getting 34mpg, which for the cold isnt a bad figure, mines 28 on a good week!! To work out your MPG divide the number of miles you do by the number of gallons you've put in.
If you want it to get higher make sure its fully serviced, change at 2000rpm and be prepared to go very slow!
sean135
hi all thanks for the quick replys i put 38 ltrs in the tank and got 210 miles for it around town its punching a big hole in the old sky rocket thank for the replys is there anyway to test the lambda sensor i worked it out and im getting about 26 to the gal
Cupra Kid
Has a TDI!!
Oct 13, 2005
3,380
Oof that is a bit bad for a 1.4! almost makes my 2.0litre look good :D
