Searching for thread: Secondary air intake fix??
satilaboy
375
ideal. i'll be losing mine then if the fix doesn't work. won't be splashing out on a new one thats for sure!
RikH
Texas Cowboy
Oct 17, 2005
2,474
Yorkshire
its nothing to do with MOT, dont worry
mines been noisy for months, and ive been meaning to do this, car went for MOT on sat just gone and its not mentionned at all.
as m0rk said the car is warm when they do the tests so it never has any effect.
I will do this come summer/weather getting better
satilaboy
375
meant to ask: rather than go through the fixing the SAI setup, or bypassing it (blanking plates etc.) can you simply disconnect it in the same way you can disconnect the MAF for example? or does this come with other issues? just trying to save myself some work.
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
I would have thought you could just unplug it, if you remove it, it leaves an opening into the system and i think it would suck air in to it, so i plugged it up.
satilaboy
375
shouldnt see why not just means it wont work might throw a code up but not sure
it's throwing up a code as it stands just now anyway. was just concerned it might mess with other parts or have other side effects: low mpg etc?
all that's left now is to try and find an elctrical connection to the pump and have a go: any ideas what/where i should be looking?
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Jack the car up, under the front left hand side you will see the pump connection is at the small end it is easy to see, i have had mine off two days now and nothing bad happening.
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
Well i have done it, removed the air pump:thumbup:, not as straight forward as the guide would suggest, getting the top hex bolt off the brackett was a bitch, i have made my own blank and i will order the proper one from the states and fit that when it arrives, i started it from cold and no lights came on, went for a drive and still nothing so it looks ok, mot in two weeks so we will see if it affects the emissions or not, fingers crossed that i dont have to put it back on.
Hi Phill mines playing up excatly the same as yours.....did you ever order that blanking plate from the states or was the one you made ok?
Any problems since removing it?
One other question........does it have to be removed or can it just be unplugged?
Cheers.
