Rhyme
Hey guys,
My first offical problem post since I got the Leon so hoping that some of you more knowledgable owners shall be able to give me an answer or point me in the right direction.
The issue is that my drivers side front indicator over the last few days has been randomly deciding that it shall not work.
I have already ruled the bulb out as the source of my problems however I tested the unit whilst it was disconnected from the actual light unit and it appeared to work fine whilst lying out in the engine - the problem only seems to happen when the indicator is fully inserted into the light casing.
I am therefor thinking that it may be some sort of earthig issue or similiar?
As I am still relatively new to the Leon I am unaware of the "Common problems" associated so I am not sure if there is a pattern whereby there is a problem with indicators - so any help is appreciated.
Thanks in advance
Mark
Thanks in advance
Mark
