Hks Bov
markillo
what happend if i put the blow off valve hks super sequencial in my car????????????:confused:
cause its cheaper and y love the pfffffffff sound....
right know i have the forge recirculating valve
AdamRoutley
Use The Force!!
Feb 22, 2007
1,827
Walsall
www.myspace.com
im sure the guys will be along shortly to tell you to search but if you want anything like the pfff sound the forge Split R is your best bet with a CAI...but other than that its been covered a lot of time so searchy searchy my friend
markillo
bjdjvhdkjvhjdhvkdfh
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
hey and what it means to convert your car from MAF to a MAP....
AND HOW CAN I DO IT????
Thats a long thing ;) Cost arm and a leg. think the ecu has to be upgraded. Not worth it just for the dv sound, just get a carbonio/kn typhoon filter with forge 007p. thats the best method with effect the ecu readings
markillo
yep i hav the 007.
and i want to buy the splitter R.
have u hear the sound of that valve?????
Big_daddy
Oct 20, 2006
3,930
Brummy
yep i hav the 007.
Well if you search theres a thread on the splitter r valve, some ppl have tried but gone back to the 007p, some have just done it to full recirc, some done it full blow off, that may trigger the engine light or cause car to stutter
RobDon
Pro Detailer
The HKS SSQV is probably the most successful BOV on the 1.8T, but the shriek does get tiresome after a while - it is NOT cheaper by a long shot. Many have tried the Forge Split-R but removed it again for various reasons, most cannot get it dialled in right.
Best option is to stick to a Forge 007P or Bailey DV30 (which is louder) and a cold-air intake, you'll get dump sound through the induction kit which is loud enough for most.
markillo
Split R issues are usually fitting problems , we have a 100% sucess rate here when we fit them
im shurre it works, cause right now i have installed de recirc forge valve.
and one friend have the ibiza cupra and he have the splitter and de intake hose, and i think its a percfect match. so next moth i will buy all my accesories hajajajaja:rolleyes:
marco
