Airbox on Leon 2.0 TFSI
cupraII
74
Hi, Does anyone know how to get into the airfilter on the 2.0 TFSI egnine. I have bought a pipercross panel filter to go inside and there is no visible or obvious way of getting in. Any advice would be appreciated. Thanks :confused::confused:
cupraII
74
Thanks for quick reply, I did try that, but it seems firmly stuck in place.
Tam
Santa in disguise :)
Feb 10, 2005
1,777
Near Reevo :)
No mate sorry, not got a clue, but i do know the correct forum that you should post questions like this in ;)
http://www.seatcupra.net/forums/forumdisplay.php?f=136
/edit to add - now been moved to correct forum.
Rampage
Trainee Northener
May 24, 2003
1,035
You don't actually need to undo the big round clip on the inlet tube. You can pull the top off of the intake (where it meets the slam panel) and then the lower part of the intake just unclips.
It means you don't need tools to take it apart.
cupraII
74
Thanks Rampage, once the other clips are off, do you just need to tug at the airbox and it will come away from the head of the engine? I believe once the airboxis off the head, its just 4 screws underneath to pop the top off th exose the fliter. Is this correct. Thanks :)
cupraII
74
Have fitted my foam air filte from pipercross, from advice, a foam filter in the standard airbox gives better output figures that a bolt on after market replacement hose & cone filter. Well if you remove the clips & clamps as stated by another member previously, the airbox is then mounted on 4 rubber mounts, you need to tug the box / cover pretty hard to snap it off, just check the 4 rubber boots are still on the underside of the box when you pull it off. If not find them quick, usually the front 2 come off, found just infront of the block in amongst some wires. Best bet to remove the box completely from thecar turn it over to remove the 12 or so philips scews to get the airbox open. If youve done it once, 10 minutes to change a filter. One pointer, when plugging the air hose back into the MAFF on the side of the airbox, grease the fat rubber seal with some washing up liquid or similar, coz its a bxxtard to get back in otherwise. :lol::lol::lol:
