pedal box f
malko69
i have 1999 1.4s ibzia my clutch pedal has snapped so i need a new pedal box and clutch cable has anyone had the same problem i need the parts to repair it but i dont no where i can get these from as i dont no the part numbers:( are they same as a vw if so which model
alb
63
Sheffield
This happened to me recently. Seat will sell you the pedal box, plus all bolts and clips for about £80 (+VAT). You may find that this will deteriorate like your last one did though, so its probably worth getting it reinforced (bolted and/or welded) before fitting it to stop it happening again.
Seat quoted me about £250 labour for 3 1/2 hours work...but i got mine sorted by a mechanic mate for a lot less than this.
Alb
Cupra Kid
Has a TDI!!
Oct 13, 2005
3,380
Chesterfield, Derbyshire
Ideally if you want to totally rectify it you'll be needing pedal box, clutch cable and clutch :( Or just do as alb said and reinforce the replacement pedal box so it will take the extra weight of aging clutch components
CraigW
Craig.
Apr 12, 2007
4,607
Hawick, Scottish Borders, Scotland
Pretty much everyone who has a mk2 ibiza has had this problem, including me!
Thats what ive did with the replacement pedal box i have. I only have it incase the old pedal box with the bolt through it goes again i will be changing it and putting the new one on.
