Hi all,
Tried doing a search, to no avail.
Think I've snapped my clutch cable... I changed from 2nd to 3rd and the clutch pedal stayed in the floor.
When I move the pedal up and down (with my hand) the cable doesn't move.
Reckon that's my problem? Because initially I thought it may have been my pedal box.
Wanting to get it fixed this morning, so quick replies appreciated!
Alex
Same happened to be when I was playing with a type r..... pop you head under and you will see if the padel box have snapped.
Hi all,
Alex
Open the bonnet. Find the clutch cable and pull it. If it comes out then obviously its snapped. Cheap enough to replace (£25 from GSF iirc) and easy to fit.
just remember to put the rubber grommets back in the bulkhead holes properly, or you'll get very wet carpets every time it rains....
