Rear washer jet not working?
Jan 8, 2007
2,958
Wiltshire
My pipe came off of the pump a few weeks ago, just a matter of taking the back cover off the inside of the boot and re-attaching it
EDIT: That's assuming you can hear the pump working but no water is coming out.
merlin051
Oil Burner!
Aug 22, 2006
186
North East, Darlington
Ok, searched the forum, cant find the answer, my pump is working, and if i hold it long enough it sprays the back window, but when i open my boot there is screenwash inside my boot, its coming from the boot catch area.
I need to take the boot facsia off but I cant figure out how it comes off, I've removed the three screws I could find (fog lights, and in the handle) gave it a few tugs and it still seemed pretty solid, so any advice on how to take it off please guys!! thanks
sssstew
Editing your spelling
yep you will need to get the trim off. its a pig of a job and you will break some clips for sure (i did about 3) i had to lever from one side with a big flat blade screwdriver covered in a rag to protect the surrounding paint, lever it a little so you can see the first clip then move the screwdriver nearer to that then lever again to pop off, theres loads though so have plenty of time and patience.
