fitting large port head to small port engine help please
Jun 1, 2007
760
thinking about fitting a large port head to my small port auq engine am i right in thinking that the large port it vvt and the small port is not so do i just swap my cams and tensioner over so i can run the large port not vvt
Jun 28, 2001
1,533
how much power do you want then??????
personally i wouldnt bother, you just want to be polishing exhaust ports and sanding inlet and making a knife edge of the v in the intake,set of decent valves,springs and lifters, cams , rods, pistons and that will be enough.
Jun 1, 2007
760
can get 350 when ive fitted the rods might been going 400+ and a different turbo
elrao
Am pretty sure people have done it on their TTs, I was planning on fitting a large port head to my APX 1.8T engine, but decided not to in the end as I am selling up and moving on.
No indications that there would be any problems. If you are getting a larger port head then you need the larger intake manifold to get the most out of it, will also help lower the spool up time with a big turbo (so I was told!).
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
you can flow a small port to have more flow than a large port, obviously flow a LP and you will have even more
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
Really? Have you seen the difference between the two.
Anyway, proper port and polish is going to cost waaayy more than a large port head, I think.
The big turbo boys, the ones who have actually done this, have posted loads of info on this in the past.
Loads of info on the vortex, also.
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
yes we have the flow readings at work, will have a look tuesday when im back at work
