LCR: have you crunched your gearbox when selecting i.e 3rd gear?
have you experienced gearbox crunch?
  • Yes
    Votes: 35 72.9%
  • No
    Votes: 13 27.1%
  • Not Sure
    Votes: 0 0.0%
  • I haven't tried pushing hard and fast
    Votes: 0 0.0%
  • Total voters
    48
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
full stage 2.
and the gear box oil was changed 2 weeks ago when I had my clutch fitted.
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
just looked at the receipt of work done as I'm sure it said they replaced the gear box oil...
it said the clutch system was bleed thats all lol so my mistake! :redface:
my car is a 05 plate and has only just had its 30k service done (had it done at the same time as the clutch!)
as for what gear box oil to use, I think* uprated brake fluid can be used?! do a search if your after advice on what to use! :)
back to topic now I think!
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
I'm not calling you a liar at all, but I cant see how changing the oil would change it at all as we are talking about an ODD crunch when not being precise enough on doing a VERY FAST gear change if you see what I mean?! (especially when its from 2nd to 3rd gear only!)
BCM
Keyboard Gangster
Feb 1, 2005
2,680
Wishaw, North Lanarkshire
I don't see how a short shift would fix this as said above, if anythin it would prob make it happen more often!
As its an even quicker shift than before and the revs loose than tiny millisecond they had to drop slightly!
UncleFester
Grumpier by the day!
Apr 30, 2006
4,764
Milton Keynes
www.facebook.com
Well that's one thing that doesn't plague the derv - revs are definitely not an issue for me. I find it easier to change gear with the short shift fitted because it makes the selection more precise.
Neil_Ireland
Leon Cupra
Apr 27, 2006
311
Dublin
Well basically you are, I changed to redline oil as I researched other forums such as tt.co.uk, vwvortex and a couple of others that I can't remember off the top of my head. They all said changing the oil improved the gear change and helped with the 2nd-3rd crunch.
I was seeing the crunch from 2nd-3rd at high rpm, not changing gear as quickly as possible...not into that as I think thats a very rough way to drive and is hard on the transmission.
Neil.
NickT
429
LB, Beds
Neil.
Fair point although I would say to change at high rpm you have to change fairly sharpish before the revs drop off. :shrug:
Mar 5, 2007
588
Me too. Happens 1st to 2nd and 2nd to 3rd when I try and make a quick getaway.
The change of oil thing is interesting.
