Does warranty cover this?
Nov 10, 2004
1,000
Colchester, Essex
Hiya,
As im taking my car in for the alarm to be checked, I thought i'd ask them about a couple of niggly things which I wondered would be covered under the warranty...
1) Rear screen wash pipe coming off (sure that will be covered).
2) Glove box needs quite a bit of force to shut or latch doesnt engage.
3) Petrol gauge does NOT go to the maximum on the gauge when full it is a little behind the full line, most cars go PAST the full line... Picky, but it irritates me...
Are they covered do you think?
KAZSTE
Newbie
Jun 28, 2006
76
cause of the problem
Hiya,
i used to have this happen a lot finally figured it out to be trying to use it when there is no water, have no stopped this and not happened since (about 1 year) hope this helps and if it was widely known then i offer to sack myself!
kriso
_______ C U P R A _______
Jan 29, 2007
2,325
Brighton
If it's not displaying correctly then should be covered. They could replace dashboard display bit or fuel level sender. I don't see how they could call it driver wear etc
AwesomeSarah
Forum Sponsor
Mar 6, 2006
727
Elecrical or manuifacturing faults are covered
So if it is the level sensor or the dash pod it should be covered
All of the above should be covered
See how you get on
Wear and tear is something that is NOT covered
Sarah
Nov 10, 2004
1,000
Colchester, Essex
I guess they will prob try that at the garage then when I take it in? I'll make sure the old petroleum is a bit low lol.
Thanks for all the helpful replies folks, muchly appreciated :)
Jun 28, 2001
1,533
yes of course all 3 of them are.
no 3 takes about 10 minutes to fix as it gets adjust via diagnostic machine
diss_50
MK4 IBIZA CUPRA
Aug 21, 2007
1,055
How to you bleed the tank before a fill up?? Is it the little thing in the fuel nossle with the hole in it to the right?? I push it anyway! lol
CHR15B
2,567
9
Scotland
When you remove the filler cap on the left hand side in the fillerpipe you can see a little plastic cylinder sort of sticking out... if you poke that forward with the nozzle when your tank is filled it will release some air and let you get more in :)
Or maybe it is the right hand side? I can't remember and I do it once a week lol!
diss_50
MK4 IBIZA CUPRA
Aug 21, 2007
1,055
thats the one chris! - sorry for the stupid explained paragraph Goble. I wasnt present in class when they taught us how to explain! - I was round the back chatting up the burds!! lol
