Blown A Hose Help
phoenix
Cossie Crusher
the other night while under full boost my car suddenly sounded like a pressure washer gone mad, Turns out i have blown the small pipe that runs from the charge pipe to the recirculating valve (oo7) , i spoke to seat direct about this to get a replacement and it appears they don't do one? can anyone shed some light on where i can get this part.:confused::shrug:
phoenix
Cossie Crusher
hello mate, so forge do a replacement hose for this? it's not the one at the bottom of the charge pipe joining to the intercooler, if you look directly behind the oil filler cap it's the small hose that doubles back on itself to the 007
RikH
Texas Cowboy
Oct 17, 2005
2,474
Yorkshire
yeah they do, but its part of the 5 part boost hose kit
im not sure if they would split the kit for you, but its worth a ring and explain your problem
phoenix
Cossie Crusher
content.asp
the one on the extreme right mate is the one i need, i'll give them a shout
lc_allan
Northern Monkey
Sep 15, 2006
3,389
Can't see the photo but how come Seat don't have a part number for it? :confused: I though every part has a # and can be ordered albeit with a bit of a wait in some cases and especially as it's a engine hose?.
phoenix
Cossie Crusher
i cant get a picture up of it and i think im confusing people, first off its a 2004 LCR if you open the bonnet look at the charge pipe, follow it up till you cant see it cos of the engine cover, remove this and there is a pipe that comes off the side of the charge pipe which immediately doubles back and is held in place by a clamp type bracket this the plums into the dump valve (007 forge) I have a part number off the hose however when quoting the number to SEAT they had no listing
lc_allan
Northern Monkey
Sep 15, 2006
3,389
Someone on here may have ETKA and be able to relook for you. I honestly can't see an engine hose not being listed. It may have another number that it goes by. If I can get a replacement little Cupra R badge on a LCR steering wheel then I'm sure a hose can be bought :lol:.
Apr 24, 2007
985
W. yorkshire
sorry pheonix i knew what you ment but i confused my self
i was thinking of the hose below the one your talking about.
I've removed mine so forgot about that one
