I have a 52 plate lcr and this morning I got in the car as normal, put my foot on the clutch to go but it didn't feel right. The pedal was about half way to the floor, still moved with the normal amount of pressure but the clutch was not releasing enough to engage a gear.
It was cold this morning, the dash said 2.5 degrees c. Anyway, I left it and went to work in my other car and then spent some time search this site for answers. I have found threads about the master and slave cylinders and also a few about bits breaking on the pedal but I'm not really sure what my problem is yet.
Its much warmer this evening and when I got home I went to the car, lifted the clutch pedal to its normal height, there was some resistance and it felt as if the pedal went over centre, all is now normal, the pedal works and feels normal and gear selection is fine. There are no broken bits in the footwell and I'm pretty sure that it has not lost any fluid although its quite hard to see the reservoir now as its dark outside.
Has anyone had the same problem, I would like to go to the garage armed with as much information as possible.
Thanks in advance,
Matthew.
Thanks in advance,
Matthew.
