I have the DBilas intake system on my cupra too and it`s amazing! The sound and the power deliever is great! Middle and high end are better, although i think i lost some torque on the low-end...But it could be just on my mind, because everybody says it`s better everyway.
Igor23 did you noticed a lost of torque on the low end?
I took an hour. The kit was complete, but on the order remember to say that it`s for a cupra...I bought it from Regal and i ordered for a 2.0 tfsi. Should said it was for a 2.0 tfsi cupra, because it`s needed to weld a small tube for the DV. If you send an email to regal they will explain better. I resolved this fast, because a friend of mine welds aluminium...
I used a forge t-piece silicone adapter, 60mm, with an alloy 25mm joiner, no welding involved, bit of a squeeze around the brake fluid tank for the dv pipe tho'...
That`s the easiest way! did you noticed any lost of torque on the low rpm`s? Everybody says my cupra is faster in all rpm`s, but i still think i lost on the low rpm`s. Do you feel the same on your cupra or is just me?
