climate control
andybag
hi. the climate control in my 04 plate 130 sport has been playing up recently. the display has been flashing on and off for ten seconds when the ignition is switched on and then it goes back to being the normal display after. is this normal as ive only had the car for 3 weeks. is there any way in which i could view a diagnostics system on the climatronic unit? any info would be great, :help:
joonspoon
175hp. 275lbs/ft.
Nov 18, 2006
361
Oxfordshire
.............has been playing up recently........... is this normal
Said it yourself, no it's not. :shrug:
Have you got access to Vag-Com?
You can run a diagnoses on the climate control through the Comfort/Conv tab (if I remember correctly) but stand to be corrected on this.
Regards Guy.
dozza.13
PS3 Tag - Dozza1979
Jun 30, 2006
1,082
Grimsby
Mine did this the other week, not done it since! Sorry, thats not very helpful is it! Try the search function?
andybag
had a quick look myself at work, found quite a few leaves in the pollen filter, not much else at first glance. also since the display went awol, the blower is blowing nowt out the vents and it aint good when it rains, trust me. trying to get it sorted out under a used car warrenty, easier for me. post a reply when i get it back
dozza.13
PS3 Tag - Dozza1979
Jun 30, 2006
1,082
Grimsby
Think mine did it cos I was driving along at speed with vents all closed, although system was turned off, flashed following morning when first started it up, only done it that one time tho! WIll probably need re-gassing soon though! :(
andybag
the car has fixed itself. still taking it in 2mo, just in case there is still a fault under warrenty
andybag
funny you should say that. apparenty the garage cleared all the faults and reset all the parameters for the flap and motor sensors. i left the garage then it played up again, yet again it fixed itself? will see how my motor goes on for now as theres 2months warrenty left.
