Finally got through to the
store number. Guy there was saying they normally sell paddle versions of the disk rather than the organic ones.
He's going to try and find out if he can get the other one.
Another thing, that local VW Specialist which remain unnamed mentioned labour being 6 hours (£350) , that sounds longer that I expected.
I am going to try and get the disk swapped for an organic one, and then buy a a Luk (without the CSC as I've got a release bearing from Allards) clutch kit for the pressure plate from (£117.07+vat):
http://www.buypartsby.co.uk/clutch_kit_details.php?recordID=4608
I've found a place that sells a standard Luk Dualmass Fly wheel for £173.71+vat:
http://www.buypartsby.co.uk/dual-mass-flywheel-details.php?recordID=491
How does that setup look?
edit:
Just noticed this description on the Allards site:
Up-rated friction disc.
This quite simply replaces the standard item, but offers a much higher torque rating capacity. This can be used in conjunction with the standard cover plate and duel mass flywheel arrangement. Due to the five paddle design the initial bite of the clutch is firm but not too harsh as normally associated with drive plates of this type. This can be used in a ‘daily driver’ with no compromise to driving style.
Price £185.00+VAT
Maybe it's worth sticking to it?
Another question (sorry!), do I need replacement bolts for the flywheel?
Thanks.
