What boost do your cars run?
cubias
144
Harrogate, N.Yorks
Hi everyone, recently fitted a boost gauge to my Ibiza fr tdi and were wondering what bar/psi you were kicking out? Myself, I cant seem to get over zero and keep getting a vacuum. I don't know if I've fitted it wrong or if theres a kink in the hose to the gauge or if the gauge itself is faulty but surely this shouldn't be right???
Are there any tests that I can do to see if its working properly? Any other tdi drivers had the same problem??
Many thanks
ini
63
Where exactly did you connect the hose?
Only the boost & EGR control system + hose to brake assist should be under vacuum.
Does it only read a slight vacuum at idle?
daveyonthemove
Smile if you like SEAT's
May 14, 2006
1,519
Wrexham
Its either fitted wrong (most likely) or your car is running ZERO boost, but you'd know if it was as it would drive like a bag of poo.
So i would check you haven't tried fitting it following instructions for a petrol car, and maybe start again.
cubias
144
Harrogate, N.Yorks
I fastened the hose on here:
And at idle I get about -0.2 bar
cubias
144
Harrogate, N.Yorks
Thanks for them, I'm starting to think that I've put the hose on in the wrong place. I'm going to go see my mechanic friend later so I'll see what he says I should do.
muddyboots
Still hanging around
Oct 16, 2002
5,739
Do you mean the orange hose ?
If so, yes it's in the wrong place, you're measuring the vacuum supply to your EGR valve :)
From memory you should get something like 1.3-1.4 bar peak if standard, and maybe up to 1.55-1.6 bar remapped (if you can find a way of tapping into the intake somewhere that is!)
devonutopia
fabia-lous
Mar 30, 2004
1,200
Exmouth / Exeter
Oh dear. :) Yep, put the vacuum pipe back on the EGR please. I'm surprised it's not gone into limp mode or similar with the vacuum box not reading the EGR. :)
You need to tap into the metal/plastic underneath the EGR using a boost gauge fitting kit. Often this involves drilling the manifold (carefully to avoid metal shards getting in) and drilling in a bolt with a small nipple fitting - to which you can attach the orange pipe.
I see a max of about 1.9 bar on mine, sometimes 2.0
cubias
144
Harrogate, N.Yorks
Woo thanks, figured it out. Fortunately the hose was still joined with a T shaped valve which diverts a bit of the boost/air to the gauge.
Muddyboots or devonutopia do either of you have a photo of where you have fitted yours please?
cubias
144
Harrogate, N.Yorks
Had a look under the bonnet just now and I have no idea where to get the reading from. To be honest I dont really want to drill into the manifold, so are there any rubber hoses that I can get it from?
Theres no chance I can get the reading off this doo-hicky here:
T. Spark
Well, I did some logs the other day, and oh the joy!
Im running 0 Bar until 2,500rpm then hitting a huge 0.9 Bar till around 50/60mph then it drops back to a big fat zero bar once again
But as said, std should run around 1.3 Bar peak, I know mine used to peak at 1.6 Bar with the map on. Earlier maps were more aggressive as far as I can tell, peaking above that.
cheshire cat
1,813
cheshire
Visit site
if you remove the EGR there are two unused threaded blind hole boses on the side drill one right thro' aprox 1/2 mm and use a threaded 4mm if I remembed right 90' elbow fitting replace and push on flex pipe, good luck you will also get to see a vac when you switch off courtesy of the ASV
