hmm... i think it´s a little bit tricky to install only the middle ones (which are on the picture) without changing the right position, and also without breaking for fingers...
and before you buy the whole vents for lots of money, you could also buy the vents from the old Audi A3 (in Germany it´s called "8L"), then you got illuminated vents... looks better, same price!
That part is changeable but its a different size on A3 vents so need to fiddle about a lot!!! I did that on mine so i had red bit on A3 vent but it was about 4 years ago so memory bad I do know it was a fiddle tho!!
i've just re-fitted all the pieces in the middle vents and those middle ones are fiddly because they're metal and don't bend as easy as the plastic ones. a bit of patience and they're good as new
