LC Inner Driveshaft Joint.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
The inner joint on my offside driveshaft is throwing grease out. Although the large clip is still in place on the rubber gaiter, the grease is coming out from that inmost end (beyond the clip).
a) should I get the complete kit and replace the whole inner joint?
b) there is an end cap on the driveshaft - does that screw off?
c) Once the end cap is off, is the joint held onto the driveshaft with a circlip?
Thank you. :)
(I've seen the photo on UKMkIV of an end coupling that let go :scary: and paranoia is setting in)
