replacemnet ECU
stuart edwards
hello folks i have a troublesome TDI alhambra Se , i have the power loss at 3000rpm and have had the N75 valve replaced but still have the problem, my local dealer has been superb in trying to find the problem but are hinting at the ECU being the root of the limp mode dropping in , has anyone has an ECU replaced for this reason?
cheers
stuart:headhurt:
ini
63
Check normal PD 'limp mode' culprits.
Dirty or worn MAF, clean the element with a residue free solvent (spray carb cleaner through it) unplug it and see if the car runs any better on the default map. If the car seems 'the same'/smoother/better with the maf disconnected, buy a new one.
VNT mechanism sticking, move the actuator rod in the middle of the turbo by hand, and ensure it has a good range of motion.
Check for boost control tube leaks (around N75 etc), also check the N75 is plumbed in correctly.
Check you MAP sensor.
Check temp sensors.
Check crank position sensor.
TDC
71
My 100pd is limping since i remapped it - i notice the temp gauge has always read 60 ish , 90% of the time, anyone know where the temp sender is located ? sorry for hijacking uit i was searching for a cure when i found this thread & noticed INI's comment about check temp sensors !!
stuart edwards
ECU information
Send me a few details mate i might be able to help
BHP
Year
ECU number etc
hello, i have just picked up on the replies the my problem, i will get the serial nunber off the ECU tomorrow and post the info, its a 2001 model 115 BHP
cheers
stuart
Jun 28, 2001
1,533
@ 3000 rpm its going to be airflow meter
if a fault code comes up saying boost pressure limit exceeded then it will be a duff turbo as the wastegate is sticking
stuart edwards
the ongoing problem
hello i have a newer alhambra now the 2001 TDI se model and its making my head hurt , i have read about checking an actuator rod , part of the turbo to see if it moves , how do ai acess this please
cheers
stuart
stuart edwards
the ongoing problem
hello, i have had the MAF replaced at the start of hunt the faulty bit, i am afraid it didnt make it better, i fitted one to my old alhambra when it went flat and that sorted that car out but no luck this time
cheers
stuart
stuart edwards
re possible faulty ECU
BHP
Year
ECU number etc
hello, the serial nunbers on the ECU are as follows
038906019FC and below that
diesel EDC 15P+ 1455
again any help is much appreciated
cheers
stuart
yellowperil
144
If your only from York mate then give me a call i am just down the A64 towards Scarborough.
Can clone your details onto a spare ECU if needed and see if that cures your problem
stuart edwards
ECU problem
hello, i would be geat to talk to someone about my troubles, i have been offered second hand ECU from a breaker in accrington but as for getting it to work on my car thats the work of the devil , i have a good mate who is a top man in this area but i need to be able to give him as much info as possible to cut down his work as he is really busy mending diagnostic equipment for various people, my phone nunber is 01347 822596 and i will be in later tonight and saturday am any help is much apreaciated
cheers
stu
ini
63
Does the power loss occur in high gears only, or does it also happen in 1st & 2nd?
stuart edwards
Re Which Gear Is Goes Wrong In
hello it seems to trip out in any gear i think i wiould have to road teat it to be totally certain
cheers
stuart
