I have an MK3, my radio has never been affected.
You will not loose your remap.
The clock on the radio fascia will automatically update itself to the correct time once you receive adequate radio signal.
Resetting the ECU will
clear codes, i.e. engine management light, but if the fault code is still within the system, the engine management light will display again after a short while.
