Right I took the plunge and took the transmitter out of my second seat key and put it in the new flip key, now the key works fine and starts the car, but the instructions I have on how to program the key to work the central locking does not
Is there anymore instructions lurking around instead of these ones?
Seat Key Fob Programming
Remote Control Programming (1997 ON)
Procedure
1. Switch Ignition ON with new key and leave the key in the ignition.
2. Mechanically lock the vehicle using the Drivers door using a second key.
3. Using the remote control press the Unlock button once, and the horn will sound once.
4. Wait 6 seconds and press the unlock button once to activate the coding procedure. The remote control will now be programmed.
NOTE: When performing programming on additional remotes the procedure is the
same, except
you press the unlock button 2, 3 or 4 times for the different remote.
For example : If programming 2 remotes press the unlock button twice with a 1 second interval between each press, repeat for 3 and 4 remotes.
5. Switch Ignition OFF.
6. Remove key from ignition and check for operation.
7. The coding procedure can be repeated up to 4 times for additional remotes.
8. The ignition must be switched OFF between programming each remote control.
Remote Control Erasing (1997 ON)
Procedure
1. Switch Ignition ON and leave the key in the ignition.
3. Press the remote control unlock button 5 times in 1 second intervals. A short horn will sound.
4. Wait 6 seconds and press the unlock button once to activate memory erase.
5. Switch ignition OFF, all remotes are now tuned in.
Procedure
same, except
Procedure
