but thats is my point how do YOU know they are ****!!!!
you dont you assume they are because someone has not afixed an expensive price tag , when you can prove to me that they are shiter than standard pads then i will accept it
why do they put a pad on that will cost no more than the said pads
cos im pretty sure the standard pads will be no different to the pads this thread is all about.
Im not saying they are good pads but they CAN NOT be any worse than standards pads
which cant result in any worse braking aslong as the car is as out of the factory
all im saying is how can anyone say they are actually **** with out trying them and ath that price they would have been worth a try if you are either on a budget or desperate for some pads
BECAUSE PEOPLE HAVE USED CHEAP PADS (mintex plane jane pads for example) and found they wore out fast, ruined disks, and faded like a mofo.
some peeps tried a range of galfer pads also, and found issues on wear etc.
like m0rk suggests... its hard use, high speed stops which show quality from non quality pads... and when they fade away from you when you least want it, you will have plenty of time to reflect on the poor performing pads once they dont stop you in time.
There's a good reason DS2500's for example get mentioned a lot. Because there are a lot of people running them and impressed with their performance over OE.
Reg90 approved pads only need to be +/-15% of OE friction level. they can easily be -15% of OE by that statement.
Its your car
