'elp me neutralize nasty 'niffs
Skii
173
Slough
Hi peeps
Now that my Leon is no longer leaking like Das Boot, I was wondering how you fellow bilge rats went about getting that horrible stench of wet socks out of the car ?
Assuming the car is bone dry from now on, will the smell eventually disappear or do you peeps have a good solution to reduce the pong ?
ta
John
Deleted member 20482
borrow a wet n dry vacuum and just make sure all water is sucked out.
use something like neutradol carpet odour destroyer..
may take a couple of goes. but does wonders..
Mike Green
Cupra crazy
May 4, 2007
431
Surrey
I had a similar problem in a courtesy car i had where the stench was awful. Short term solution - they sell potent air fresheners which really mask smells for a few weeks. Then that gives you a bit of time to do as what mick says.
Skii
173
Slough
Thanks chaps - looks like Argos has some carpet washers for about £50, might as well invest in one eh ?
thanks again
John
thanks again
John
wickes do a wet n dry vac for about £40 i think.. unless they have put it up.
they work well as i use one at work....i'm a plumber so i know...
its just they are a abit loud...
they are a very handy item to have...multiple uses.
