Delocking Leon
Cupraloon
Ok Panic over....... sussed it, it was stuck after having that side of the car painted a few weeks ago presumably...... :rolleyes:
Drivers door now delocked, colour match is a bit suspect, but i can live with that..... just, :whistle:
Cupraloon
Delocked
There you go BCM, just for you.....
I might repaint it at some point if can be bothered, but it's not tooo bad..
lc_allan
Northern Monkey
Sep 15, 2006
3,389
I'm currently painting one in Luna Grey and it is a bitch to match. I think Halfods have mixed the paint wrong. Tw@ts!. Slightly off but I might fit it anyway for a bit.
Cupraloon
Delocked
Yes mate, thats were i got my paint from, i put 3 coats on, let it dry, rubbed it down, laqured it, t-cut it and it's still slightly off colour...
Don't forget to do your 38 fuse relocate, other wise you won't be able to get in, did mine about 2 weeks ago, just to make sure it wasn't gonna blow, before doing this..
http://www.seatcupra.net/index.php?option=com_content&task=view&id=527&Itemid=6
Don't suppose anyone else would notice it, but....:cry:
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
what colour primer did you use, because that can and looks like it has affected the end result, if it was me id take it off and do it again
sorry
Mar 26, 2007
2,020
S.Wales
it doesnt look that bad but it is noticeable. funnily enough i have spent the last two days spraying and respraying my caps before i de-lock it. Is it necessary to do the fuse relocation? i got the impression from pabs guide it was optional.
