markfranklin
61
Hi
Following delivery of my FR TDI with a quarter of a tank of diesel in it, I went to the pumps to fill up.
However, the nozzle did not seem to go in very far even if I twisted it round, almost as if the shape was wrong.
As it was not in properly, every time I squeezed on the handle only a small amount of fuel went it before the cut-off kicked in on the nozzle. I spent about 10 minutes putting in a few pence at a time, eventually gave up and ended up with about £12 worth.
Has anyone else had this problem?
Many thanks!
Yep, I had that problem first time I filled my 1.9TDi up.
I'd pulled up at the only free pump with the filler on the far side away from the pump, so I had to bring the hose round the back of the car to reach.
I figured that was the problem. Now I queue until there is a free pump on the 'right' side :sleeping: Haven't had a problem since.
I've had petrols up until now, don't know why diesels (or supermarket diesel pumps) are 'fussy' about how the filler is inserted.
Hi
Many thanks!
Er...... this is probably more of a problem with the petrol station pump than with the car........ :rolleyes:
Went to a different garage, different town, same problem. However I put the nozzle in, at whatever angle, it just will not put any fuel in. I get the auto cutout all the time.
Eventually twisting it round right pushed against the side it did let me get a whole tank in, but not without quite a few cutouts and re-adjustments.
This is strange!
give it a good push in, its a tight fit when they are new.
It wont go all the way in, perhaps 50% in.
only goes about half way in on mine too, will rotate when in though. I believe it's designed to stop muppets filling their diesel up with unleaded. It is a bit fussy, but having filled up a couple of dozen times now it does seem to have freed up a wee bit now.
you need to release the pressure from the tank if you look at the filler neck there should be a black nob push it with the nozzle from the petrol pump and that will relese it
