ian.main
Antone know whats on the market re short ram induction kits for the Mk 2 Leon Cupra
I think that Dbilas is great, would of got that if i didnt have one already.
RAM-Air
Hi guys,
Tonight I put in the CARBON airbox from Oettinger ( www.oettinger.de )
Looks "top-$" but the "pin" to hold the hood open cannot be put to rest vertical, because the box is in the way...
bad construction.... :whistle:
What is the result with the DBilas kit?
id also be very intrested in hearing peoples opinions of the DBilas kit compared to the neuspeed Kit cos i was going to buy the neuspeed kit until i saw that kit
The result is an overwhelming YESSSSSSSSSSSSSS!!!, A bit of a pain to fit, but worth the money/effort, I had to replace the flexible pipe that connects the main pipe to the turbo intake, with a Forge t-piece pipe, to connect the recirculation pipe, (below the air mass sensor), the power delivery/sound is most impressive :D
Also, I fitted the Forge DV, and the Side short shift, which improves the gearchange immensely, don't notice the dv at all....
Absolutely no issues fitting the Evoms and hand on heart has improved performance...........As said before this unit does not suffer from heat soak...........:p
where did you get the side short shifter mate?
