Hi all, so I own a 1.4 seat ibiza mk2. Been using a Toxic T500 2 channel amp with a kenwood sub and JBL rears (front speakers are powered by head unit)
Anyway, I took the amp and everything out a few weeks ago. Installed them back in and they won't work! While un-installing, I got a spark from the switch cable while unscrewing it. (Thought I'd unplugged the live.. Guess I hadn't!) Which blew the fuse on the amp. I would have thought that any surges that it could have caused would have been saved by the fuse (hence having one). Well, the amp won't work. It has a green light for power and red for protection and the red light is showing every time.
Some things I have tried:
Unplugging everything, plugging back in.
Checking everything is plugged in properly.
Moved the ground to a different area (it is on bare metal)
Swapped the speaker cables into the amp around incase I had put neg into pos. etc.
Removing and inserting the fuse while turned on. Told this could reset the protection but to no avail.
Replaced the (15A) fuse.
Used a 20A fuse instead.
Tried knocking the head unit's volume all the way off before turning it on.
The volume on the amp is at half.
Tried unplugging all the connections that lead to the speakers.
And nothing!
Any ideas please? This has me stumped!
And nothing!
