Hi everyone.
After my ecu decided to take a good bath, it started playin quite a bit. Now I've blown it with air and it's dry and everything seem to be working ok. Problem is that I've seen the circuits are all oxidized and some components are rusted. Before rust will eat everything up I'll need to change the ecu.
Ecu part # is 038 906 018 FB and if I got it right it's just for the beeza. Golf's and A3's with same engine code [ASV] seem to have different ecu's [the last two letters are different]. Does anyone know if I can use some different ecu from same engine code provided that I change the chip and the immo chip with mine? [mine is mapped so I'd like to retain the extra power].
Golfs are much more common than beezas in the scrapyards.
I can't even drive via del corso! it's forbidden to normal traffic!!
