If u tap the indicator left or right slightly it flashes 3 times for when you on the motorway,
they should add that feature to bmw's but when the steering wheel is turned slightly so u know when the f£c£$rs are pulling out in fromt of you.
I test drove an astra before deciding to go with the beeza and thos stalks are wierd; how many times did you nearly snap the indicator off trying for the click???
H
Very fancy cars mind just i trust VAG more.
H
if your stationary and move the wheel i think its cos all the power is goin into the power steering, try tunring all lights on buttons on and air or full then turn the wheel everything dips, my fiesta was really bad with this!
I only found out about the lane changin indicator thing the other week after driving a new astra that has weird indicators and wiper stalks that you just tap for use in a similar way.
The new astra indicators sound like a nightmare!! What happens if you want to turn them off manually because you change your mind or something - do you have to indicate the other way or something?
- On the top of the windscreen wiper stalk, you have the Intermittent Wiper interval control.
(so you can speed up or slow down your intermittent wiper speed. Neat)!
