110 miles out £20??
ScotlandToIbiza
Ibiza 1.4 Mk2
Apr 23, 2007
208
Ayrshire
somethings wrong here. Its only a 1.4 and I don't rip it everywhere!
also the drivers side lock is gone all weird on me :headhurt: it turns like 1 and a 1/2 turns until it unlocks, but it locks fine just the normal 1/4 turn!
Edit: forgot Im getting 2 new front tyres tomorrow, they have been wearing on the inside whats this down to?
cheers for any help :)
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
110 from £20 is 16v territory :) short journey's by any chance ?
drivers lock is removable easy enough - theres an allen screw under a grommet just inside the door level with the handle to get it out and check it over
if my old brain serves me right although the handles are different you should be able to swap the lock and bits over from the passenger side if its all ok - be warned it can be fiddly so a kitchen table job really
inside wear only would suggest either negative camber or severe toe out on the front alignment either way when you get the tyre's have your tracking checked too should yield a sign or two to get it sorted
Mckellar
short, cold engined journeys
maf sensor buggered
induction kit
throttle body gunked up?
Dolly_Gti
G60 spooling up.
Aug 15, 2006
1,412
china town
£20, im lucky to get 100 mile in my 16v not that im heavy on the throttle or anything :rolleyes:
tyre wear on the inside could be something worn ball joints ect id get it checked over for anything obvious like worn bushes/ball joints by someone with abit of mechanical know how. Or you could just go for a wheel alignment thats usualy around £25 and can probably be done by the people supplying your tyres..
andyj
There's no F in Quality..
lock are easy to swap over, don't even have to swap the mechanisms apart.... just remove the two handles, swap them over and refit ;) 10min job.... did the same on Em's 1.4 at the weekend due to the lever on the inside of the drivers lock disintergrating !!!
you can actually buy a repair kit on EBay for about £8
ibiza_streg
221
Cornwall
I thought my 1.4 was bad on fuel! I could probably have 160-180 miles out of 20 quid!
Yeah my tyres were unevenly worn on the inside I just got the wheels aligned for 11 pounds aparently both the front wheels were pointing inwards by about 4 degrees!
chris285
leon mk1 fr tdi
Nov 26, 2004
1,849
lincoln, uk
i get about 180-200 miles off 20 quid from my 1.4, depends a lot on if i have been stuck in traffic or given it some welly at any point
sunderwood
i got 70 miles off 4 quid the other week. was well impressed.
TDi FTW
16vcupra_andy
U guys must really thrash ur cars!
i drive hardish most of the time and i can get 150 miles out of my 16v cupra for £20
ScotlandToIbiza
Ibiza 1.4 Mk2
Apr 23, 2007
208
Ayrshire
I'v done 120 miles now out of this £20 so far and it was at red then it sprung back up to 1/4 just tonight :confused:
I remember back a few months I put the same amount in and the guage didn't even flinch until a few days later :headhurt:
EssexIbiza1985
293
i get roughly 120miles to £20. I do tend to rag it tho. 85mph down the motorway on way home to essex dont help! thats only about 26 mpg at todays prices :cry:
