Condensation help?
gooner84
Ok so i bought a 03 ibiza and 2 days after i realised the drivers side headlight misted up, so i found this site as and joined up and searched for threads relating to this problem which were a great help.
I dried out the headlight and drilled a hole in black cover as suggested and went to fit a breathing tube as one person suggested but instead used a rubber sleeved grommet off a plug which worked a treat no steam and no water inwards for about a week or so even when driving in heavy rain and spray off roads........until yesterday when the weather was a little chilly again i drove 20miles in the morning and went to get into car 10 mins after stopping and noticed it had fogged up again.
So i cleared it of mist yesterday and carried out another 2 methods- silica gel and vaseline around rubber seals, again it cleared untill i drove it home and then got out and noticed a little mist again!!
Any ideas on what else i can do or as to why it had been so clear after initial fix through all conditions and now its gone back to being a pain again??
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
I seem to remember the drivers side one mists up more due to it being more open and closer to the belts flicking water at it
the passenger one is more closed in by the battery
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
please search people there is tons and tons on this subject mine where really bad had them replaced under warranty but they have started to do it again
gooner84
I did a search when first come across problem and ive pretty much done all that has been suggested just wondered if there was any other tips, as surely this is not only a nuisance but maybe mot failure or pullable problem?
rashcupra
Oct 15, 2006
6,517
crawley
ive got silica gel in the back of my headlamps and that has stopped it for most of the year but recently ive got a very very slight blur of condensation you can see it here on the drivers side light
gooner84
nice motor rashcupra!! yea as i said ive got a breathing grommet in middle plus silica gel packet and vaseline round seals and all was good until 2days ago
rashcupra
Oct 15, 2006
6,517
crawley
ive got a massive pack of silica gel its about 10cms-10cms and 4cms thick of silica gell in each light unit and im getting a bit of condensation back in the drivers side 1!!!! :censored: really annoying as it ruins the clean look of the front of the car!!!!!
dozza.13
PS3 Tag - Dozza1979
Jun 30, 2006
1,082
Grimsby
Once the silica gel has absorbed a lot of moisture tho it will stop being as effective mate, u might just need to change the packets??
rashcupra
Oct 15, 2006
6,517
crawley
i changed them about a month ago from alittle pot of silica to this humungous 10cm-10cm by 4cms thick pack :lol: only just fits :lol:
Hudson
389
Bilston.
You can ofc burn off the excese water quite easily using a folded sheet of white papaer and a little patience. Put the white paper over your headlight turn on your beams and the water should burn off.
Obvious it can come back but i heard its worked for other folks before.
H
rashcupra
Oct 15, 2006
6,517
crawley
putting a hairdryer in the back of the light makes it dissapear but the diesese will always come back
DFMM
Silica-Gel needs drying/regenning, regularly ( just ask a school science teacher ). Just put them in a warm top-oven at home, and cool them in a sealed poly-bag, before refitting them.
The other point, of water spray coming off the auxialliaries drive-belt seems worth screening-off with heavy-grade polythene sheet taped in place with strong "DUCK TAPE"
