Catch Tank connector size...
Nov 2, 2004
9,335
South Wales
If you can find one yeah.
Mine were 15mm which i sleeved with the clear garden hose that the catch tank came with, then my 19mm tubing fitted straight over the top nicely.
str8ballin
211
Cheers PhilW.
Quick question... did you remove all of the PCV system?
And also while im getting the Catch Tank I will need some extra hoses...which Size should I get?
Nov 2, 2004
9,335
South Wales
Blanked the connection to the inlet manifold, which is underneath.
Removed the PCV valve under the inlet manifold which looks like a T-Piece.
Ran the rocker breather and breather from the removed PCV to catch tank and then to atmos.
Blanked the turbo inlet pipe off where the mushroom valve used to be.
str8ballin
211
Right thats what i'll do then!
How about the brake booster line with the Y rubber hose... what did you do with that?
What size hoses should I get 19mm only? any other bits I need to but before I do it?
