1k to spend, advice
Jan 1, 2007
726
Retford, Notts
Now then...
Totally standard TDI150 Cupra. Would like to get a remap from Mr.Bell and a panel filter, so that leaves me with roughly £650 to spend.
So, what are the options?
Clutch or Suspension or something else, what do you think?
DIFT
Torquing all the Torque
Oct 8, 2004
1,546
Kent/London
Clutch 1st, then if your going with Mr Bell, get a slightly more aggressive map, Whats left get a green panel filter, and ARB's with anything left.
slick
Bit of an animal
Mar 15, 2005
1,124
Essex
Clutch without a doubt.
Then remap, as said, more aggressive map to use the clutch abilities... then i would mufflerectomy (£60) and panel filter.
Then save up for 312mm brake upgrade and suspension upgrades!
Balf2k
208
South East Kent
ARB's would be my choice. It was one of the last mods I done but if I had of known it would make so much difference I would have got them much sooner. Enjoy the remap :)
ChrisUK
Eat My Smoke
Oct 20, 2004
2,258
Liverpool, UK
If your getting a remap from Pete @ Bell Auto's - you will DEFINITELY need a clutch upgrade !!
I had a mild map put on mine from Pete, & the clutch went pretty quickly. After I got the Sachs racing clutch, Pete put a more aggressive map on mine, and it totally blew the old one away.
You will need to put a few quid towards the clutch though mate.......
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
you could get a forge FMIC, short shifters, dogbone mount and a full set of hoses
you wouldn't get much change from £1k though
You'll get more change if you join in the group buy on the Forge FMIC's that's currently running ;)
slick
Bit of an animal
Mar 15, 2005
1,124
Essex
Well the TDI has a more than capable FMIC on the TDI STANDARD... so doubt there is a need, and unless your running silly pressures on a upgraded turbo, hoses standard are fine on a TDI, as for the short shifter, i think thats one think you need to buy on a TDI to quicken the 0-60 time... dog bone mount is also worth it, just have to bear with the shakes for a little while, while the mount softens a little at the beginning..
