Seat Aura pin outs
bigfella_V5
MG ZS 180 - V6
Feb 25, 2007
274
Anyone know the pin outs of the Seat Aura HU? Is there remote on feed? The same as the blue wire on aftermarket units?
The reason I'm asking if I will soon be fitting my Infinity Basslink active subwoofer, I'm also not sure if I should use the speaker level inputs or get a line level convertor?
Are the speaker cables the standard colours?
Sorry about all the questions your help would be great.
matt459
im looking for the pin outs but no one seams to know, nothing i can find in internet.
have you found anything yet?
sylten
Did you get it to work?
I connected the remote-cable to pin 11 on the HU. But it doesnt seem to power up the amp. Can I connect it to pin nr6 instead??
bigfella_V5
MG ZS 180 - V6
Feb 25, 2007
274
I connected it to IGN live in the end as I could not find a spare pin to go in the ISO plug. I did this from the headunit at first but then when I was working on the car I had the radio on (and sub with the keys in) and it caused a flat battery. I have wired it off the ignition live from the headlight switch now so the sub turns off with the key and I can still have the radio on, not draining the battery.
