the injectors as std don't have the headroom at 3bar to safely run a k03s properly
maybe he doesn't intend it to make any more power than it does now - or maybe he doesn't have the tools/knowledge to adjust the timing of the injectors (more likely)
you do need to ensure that your fuelling is 100% spot on, remember the Ibiza lambda probe isn't wideband....
I think I'll call him again tommorow now I understand the fpr's a bit better. but I wouldn't have thought he doesn't have the tools/knowledge because he does alot of VAG work inc. big turbo upgrades and I've always found he knows his stuff.
Ask him what software & what tools he uses
then research it! It might be cheap, but at the end of the day - you need to be sure it's the right thing
I've seen the work of his big turbos. Leave a lot to be desired.
I think all the south wales boys know the golf i'm on about.
I've heard someone mention that golf before actually...
however, I go on the briscoda site sometimes and they've got nothing but good things to say about him on there.
well I've just ordered one to be safe. If I don't use it I'm sure it'll be easy enough to sell tho.
They are more expensive than I was expecing...£70 from dealer, £60 from ECP and £40 from westec...it wasn't a tough choice where to buy it!
