k03s on 3bar fpr...and without fmic
Mar 10, 2005
1,439
Walton on Thames
the injectors as std don't have the headroom at 3bar to safely run a k03s properly
maybe he doesn't intend it to make any more power than it does now - or maybe he doesn't have the tools/knowledge to adjust the timing of the injectors (more likely)
you do need to ensure that your fuelling is 100% spot on, remember the Ibiza lambda probe isn't wideband....
I think I'll call him again tommorow now I understand the fpr's a bit better. but I wouldn't have thought he doesn't have the tools/knowledge because he does alot of VAG work inc. big turbo upgrades and I've always found he knows his stuff.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Ask him what software & what tools he uses
then research it! It might be cheap, but at the end of the day - you need to be sure it's the right thing
Nov 2, 2004
9,335
South Wales
I've seen the work of his big turbos. Leave a lot to be desired.
I think all the south wales boys know the golf i'm on about.
Mar 10, 2005
1,439
Walton on Thames
I've heard someone mention that golf before actually...
however, I go on the briscoda site sometimes and they've got nothing but good things to say about him on there.
Mar 10, 2005
1,439
Walton on Thames
well I've just ordered one to be safe. If I don't use it I'm sure it'll be easy enough to sell tho.
They are more expensive than I was expecing...£70 from dealer, £60 from ECP and £40 from westec...it wasn't a tough choice where to buy it!
