Erm - sorry if this is a dumb question but...
...what are spacers exactly and what do you do with them?
Cheers - Cobraman2007
Ive 14mm on the front. 10mm on the rear, I like it, i like it a lot.....
the rear is narrower than the front so widening the rear only to me makes just as much sense to balance things up a little.
hubcentric spacers can be bought second hand you know rob!
the bolts arnt expensive, a tenner will get you ten (dont forget that the std locking nuts arnt long enough once you fit the spacers.) bolts, I wouldnt bother with the fronts as they will still be using the locking nuts which hopefully would deter thieves from nicking just two wheels.
