Poor mpg help
TommyCupra
Just Like That
Mar 30, 2005
217
West Yorks
Hi
been having problems with mpg, getting low 20s at best and thats with driving like grandad.
Vagcom'd the car a few days ago and it came up with
16501 - Engine Coolant Temp. Sensor (G62): Signal too Low
P0117 - 35-10 - - - Intermittent
So i replaced it. The cars still fueling bad and it smells of petrol and idles bad, any ideas on what i should be looking at? The cars just had a new maf sensor, not sure what it was like before this as i've only had the car for 3 or 4 weeks.
Just about to vagcom again so will pop any errors up
TommyCupra
Just Like That
Mar 30, 2005
217
West Yorks
Address 01 -------------------------------------------------------
Controller: 6K0 906 032
Component: 1.8L R4/20VT SEA 0002
Coding: 11500
Shop #: WSC 00000
5 Faults Found:
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-00 - -
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17524 - Oxygen (Lambda) Sensor Heating: B1 S1: Open Circuit
P1116 - 35-10 - - - Intermittent
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
Readiness: 0000 1000
Am no pro at vagcom lol only the 2nd time i've used it.
Quikie
does you car not run like a bag of balls? Oxygen (Lambda) Sensor B1 S1: No Activity
pdcupra
Ibiza-less
Aug 11, 2006
743
King's Lynn
my car is shite on petrol too at the moment, and on a recent track day with a mate who has a cupra, i was averaging 9ish mpg and he was getting like 15-16 we were both nailing it too. Im going for new maf first
Havok316
Boost Junky
Jun 6, 2006
1,220
Weston-super-Mare
no tryingh to be funny here but maybe the computers sensors arent reading it correctly. Ive always been told the MPG computers arent accurate and only use them as a rough guide which im sure u know. Also noticed the instance u change to a different fuel it does read a crap MPG until you've topped a few times and the ECU has adjusted? The reason i said this as you mentioned u done it on a track day i assumed you changed from something like tesco 99 or V Power to Race Fuel 103 or similar?
JKing
Cupra-R
Aug 9, 2003
598
Mansfield, Notts
photobucket.com
Get the Lambda sensor checked then clear all the fault codes and do an ECU reset with a nice tank of 98 ron and see how it is then.
If you've got VAGCOM do a flow test on the MAF to see if it's reading low. Would put money on a new Lambda sorting it though.
May 2, 2006
2,758
replace temp sensor and lambda, reset the ecu/clear codes and see what comes back
EDIT, just noticed you changed the temp sensor already, did you clear the codes after you changed it? might be a old code ......
pdcupra
Ibiza-less
Aug 11, 2006
743
King's Lynn
the car has been run on only v-power for the last 30,000 miles!!!! and i used v power on the track day too. I wasnt just going by the trip computer either - we both had a full tank, and after a few sessions i was just under half, and he was about 3/4 full. I notice it with day to day driving too, getting about 23mpg, and thats not foot down fun either!
May 2, 2006
2,758
u got any codes?
TommyCupra
Just Like That
Mar 30, 2005
217
West Yorks
My onboard comp doesnt work so i use a spread sheet to work mine out :)
Anyways cars been in garage today and the faults looked at. Was coming up with CTS MAF and Lambda on there handheld kit so we reset all fault codes and its back again on Tuesday to be fixed. MAF and CTS sensors are brand new so if there buggered i should get money back or another :)
Smoki333
472
Wiltshire
Defo Lambda knackered, if im right its the main one before the cat, so your probably overfueling big time.
Had my lambda after the cat go, and was only get best about 28average (Driving like grandad!) Now replaced an workin, im gettin 35average town driving that is!
