I see, cheers.
Is there a better way through the bulkhead than the grommet under the scuttle panel on the drivers side and is routing down either side easier than the other?
I wasn't paying much attention during the electronics talks at school obviouslyNo no no no no no no no no no NO!
Take it from the battery direct. The cable between that distribution box and the battery can't cope with big loads.
I wasn't paying much attention during the electronics talks at school obviously![]()
Cheers for the link.
Is it still considered wrong to route rca leads down the same side as power cables?
keep them apart
shouldnt really be running signal wires next to power wires as it can cause a low hum or an interfernce
also make sure you've got a good grounding point!
Got me slightly worried now. I wired my active sub to the power block under the dash on somebodies recommendation.![]()
On the positive side, i've been using it like this for 2 years with no problems........
Might just look into this further![]()
