Feb 25, 2007
657
stroud
my car has a g60 conversion flywheel and clutch set up the clucth is toast so i phoned up jabba and asked them for a part number of they clutch they use
they refused point blank to tell the the sachs clutch part number ask they said it would comprmise there bussiness they want £150 for a sachs replacement where HOPEFULLY my local motor factors can supply a g60 clutch sachs item for £70 part numbers to follow soon THANKS JABBA SPORT
** got the same set up mate! ** got the invoice from jabba at home might hav the part number on it il have a look for you when i get in from work tonight
Its just a G60 clutch or VR6 clutch in 228mm size.
SACHs power clutch is an option although mrsB lupo 1.8T has started signs of slip in 5th with little milage on it since fitting (relatively)
Standard part numbers...
G60 Flyhweel/VR6 Clutch
Fly - 037 105 273 A
Cover - 021 141 025 FX
Friction - 021 141 031 CX
Bearing - 02A 141 165 A
thanks bill the clutch turned up today sachs item 228mm £70 not £150 like jabba sport
