So are you saying you can't put a kit together for me Mike?
As for the next mods......Eibach ARB's on the way, BF exhaust in the group buy and the Forge TIP when it arrives. After that, maybe phase 2 map........i'll probably chat with you guys at Inters about that.....
you will have drive by wire then,
when you first turn on the ignition if you have a EPC bulb - then you have it.
Dbw
Will have to check, but is DRIVE BY WIRE, all cars which have a throttle cable? or is it the ones which have an electric throttle.
